Neutral Safety Switch?
2001 ISUZU RODEO
221,000 MILES • 2.3L • 6 CYL • 4WD • AUTOMATIC
WORNOUT4WD
  • 5 POSTS
I have had at least 6 Neutral Safety switch's installed on my Rodeo. The last one was replaced 3 days ago and went bad this morning! The symptoms are the dashboard gear selector indicator does not synch with the actual gear I am in. I have the vehicle in Drive, but the dashboard indicator says I am in Park....when I turn the key off and restart the engine, the light doesn't come on at all anymore, and the car shifts hard and downshifts hard.....I have no idea what can be causing the switches to keep burning out!!!!
Nov 30, 2014 at 3:03 PM
HOMER1967
  • 875 POSTS
do you have a check engine light on? this doesn't sound like a neutral safety switch issue to me.it sounds like a t.c.m. issue or speed sensor issue.let me know about that light. Check out the diagrams (Below). Please let us know what you find.
Apr 5, 2021 at 4:53 PM
WORNOUT4WD
  • 5 POSTS
No codes. Transmission light doesn't come on. No check engine light. Had a new switch installed last Tuesday, Switch went bad on Sunday morning. At $265 a pop, I am just at a point of not knowing what to do with it. No one seems to know what is causing them to stop working.
HOMER1967
  • 875 POSTS
I suspect that you have a faulty t.c.m. have you tried to take it to a transmission specialty shop?
WORNOUT4WD
  • 5 POSTS
Yes, they are going to check the wiring harness to see if there is a short somewhere.
HOMER1967
  • 875 POSTS
that's good.please let us know how it turns out.
WORNOUT4WD
  • 5 POSTS
I will. This has been an ongoing issue with this vehicle, and as far as I can tell from researching the internet, electrical problems are fairly common with Rodeo's.
HOMER1967
  • 875 POSTS
yes,please let me know how it turns out.
WORNOUT4WD
  • 5 POSTS
well 3 switches and a lot of frustration, I went about 6 months without any problems, until this morning. I backed out of a parking space, and the switch went out. Something about Putting the vehicle in Reverse after it has set parked overnight, causes the switch to go out. Every time it has gone bad, it happens if I put the transmission in reverse and back up when I first start it up after sitting overnight.
