Neutral safety switch removal
1998 CHEVROLET CAVALIER
146,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
CELAWSON53
Having a problem removing neutral safety switch.
Nov 2, 2019 at 4:35 PM
Good evening,
Remove the 15mm nut on the shift linkage and then the connectors for the neutral switch. Remove the attaching screws and lift it up and off.
Nov 2, 2019 at 4:57 PM
CELAWSON53
Somewhat. How do you remove the mount on neutral safety switch?
Nov 2, 2019 at 5:06 PM
Just remove the 2 attaching bolts. I attached a picture of the screw locations.
Nov 2, 2019 at 5:15 PM
CELAWSON53
The shifter linkage mount binds the back bolt?
Jul 15, 2022 at 11:39 AM
You must remove the shifter linkage first.
Jul 15, 2022 at 11:40 AM
