It looks like you will need to purchase or rent an oil pressure gauge kit so get a reading for the transmission pump pressure. That will be the first step in diagnosing transmission issues. Of course make sure the fluid level is correct and in proper condition. If you can, you should also scan the system for codes for any clues that may relate to transmission engagement.
Hope this helps,
William
Mar 4, 2026 at 6:03 PM
