I can't find the neutral safety switch on the car listed above. please any help. I looked everywhere in the car inside and out and no luck.
Aug 7, 2019 at 11:08 AM
CERTIFIED EXPERT
Good afternoon,
There is no neutral safety switch. The PCM and the starter relay control the operation of the starter.
The ignition switch sends a signal to the PCM. Then the PCM looks at the position sensor on top of the transmission to be sure it is in park or neutral. When it gets that signal, it sends power to the relay.
Image (Click to enlarge)
Aug 7, 2019 at 12:15 PM
CALOBETO IBARRA
MEMBER
Thanks so much for your help, please can you guide me? My car shut off while I was driving did not started back up. no crank when I turn the key to the crank position lights on the dash go off even when the battery is fully charged. so everything indicated that it was the neutral safety switch, but there is not a one. I can only start it jumping the starter on the relay but the alternator doesn't charge the battery back up, but if i put power on the alternator connector i think is a 3 or 4 pin (red wire) alternator looks like charge it. I test all the wires coming from the ignition switch but everything seems to be fine I m lost, because I search for the part and it is one but i can't see it.
Aug 7, 2019 at 1:20 PM
CALOBETO IBARRA
MEMBER
Thanks a lot for your time and help.
CERTIFIED EXPERT
Start with checking the fuse listed as PCM fuse at the relay. Test it for power in the start position.
Aug 7, 2019 at 2:19 PM
CALOBETO IBARRA
MEMBER
I check all the fuses and relays everything is good. when I turn the key to the crank position while I turn the key lights go off and when I return the key lights go on in the dash key .
Aug 8, 2019 at 2:25 PM
CERTIFIED EXPERT
This sounds like an ignition switch or possibly dirty battery cables. Make sure the cables are clean.
Do you know why when I start the car jumping the starter and the car is running the alternator doesn't charge the battery? What should I check for symptoms in the ignition switch? Should i check power on the yellow wire (starter wire) coming out from the PCM? I appreciate you.
Aug 8, 2019 at 2:52 PM
CALOBETO IBARRA
MEMBER
The battery stays on when the car is running. (only jumping the starter)
Aug 8, 2019 at 2:54 PM
CERTIFIED EXPERT
Check the fuse I listed in the diagram and make there is voltage to the 2 wires on the alternator with the key on.
I attached a diagram of the ignition switch. Check the yellow and pink wires at the switch.
Aug 8, 2019 at 3:02 PM
CALOBETO IBARRA
MEMBER
This is what the car does even with the battery fully charged.
Video (Click to enlarge)
Aug 8, 2019 at 4:21 PM
CERTIFIED EXPERT
Okay, did you check the switch output as I suggested?
Aug 8, 2019 at 4:41 PM
CALOBETO IBARRA
MEMBER
Sorry I apologize for the delay yes I just check the following:
1. dim (10A) fuse shows power all time
2. ignition Pink wire key on shows power and yellow shows power when I turn the key to the crank position
3. alternator connector with the key on. There's 3 wires red,gray and orange orange shows power the other 2 wires shows .37v and .46v.
Sorry boss thanks for your help.
Aug 10, 2019 at 5:20 AM
CERTIFIED EXPERT
Okay, you may have either a bad alternator or the PCM. From here forward, you need a scan tool that can read the charging system to see if the PCM is turning on the alternator to charge the battery.
Aug 10, 2019 at 5:26 AM
CALOBETO IBARRA
MEMBER
I just change the alternator same thing.
I have autel708 scanner what do I look for in my scanner I was doing some out put test with my scanner but starter and fuel pump says disabled I tried to turn the radiator fans on it won't turn on the fuel pump sounds like turns on every time I command to turn on .
Aug 10, 2019 at 7:57 AM
CALOBETO IBARRA
MEMBER
Also the lights in the dash for the gauges don't turn on.
Just the lights like the ones show on the video that I posted.
Aug 10, 2019 at 8:02 AM
CERTIFIED EXPERT
You need to see if you can turn on the alternator. There should be a section for the charging system. If not, then your scan tool will not do this check.
Aug 10, 2019 at 3:39 PM
CALOBETO IBARRA
MEMBER
Hey boss, I want to bypass the pass-lock is pk3 do you know what wires should I deal with? And how do i test for the resistance?
Aug 15, 2019 at 6:38 AM
CERTIFIED EXPERT
Why do you want to bypass this system? Is there an issue?
Aug 15, 2019 at 12:21 PM
CALOBETO IBARRA
MEMBER
I was just going to try it if it works because I watched some videos about the same thing.
Aug 15, 2019 at 1:07 PM
CERTIFIED EXPERT
I know how to do it but am very uncomfortable sharing it as it is a safety system and I am not a fan of disabling any safety system.
Aug 15, 2019 at 1:10 PM
CALOBETO IBARRA
MEMBER
Okay, not problem I understand. because you don't know if someone is doing it for bad purposes. I will look at some of the YouTube videos I was just asking you because I don't see any videos for 2000 Le Saber and i don't have access to the wiring diagrams but thanks for all your help.
