Where does the negative battery cable mount on the motor?
2000 DODGE NEON
240,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
MARYS2590
MEMBER
1 POST
FOLLOW
I could use a detailed description or a diagram. The cable is in really bad shape and plan to replace it and the new cable is very long.
May 22, 2022 at 3:00 AM
SQM
CERTIFIED EXPERT
The battery ground should have two spots, one near the battery and other lower left side of the engine.
Are you able to trace the existing ground wire? Or is it missing?
