Engine swap
2002 AUDI A4
132,000 MILES • 1.8L • 4 CYL • 4WD • AUTOMATIC
ALONZO LOPEZ
Need to swap a amb to atw would it work. don't know if a 99 atw fits on mine mine is a amb.
Apr 23, 2019 at 10:21 PM
Welcome to 2CarPros.
The engines themselves should be the same. The coding is needed if you do internal work on the engine. However, if you need to make sure the new engine also came from an automatic. The crankshaft is a different size between the auto and manual transmission.
Let me know if this helps.
Apr 25, 2019 at 3:06 PM
ALONZO LOPEZ
Thank you. For the help
Apr 29, 2019 at 3:50 PM
Happy to help. Did you get things changed yet? Did everything work out for you?
Apr 29, 2019 at 7:14 PM
