Need to replace rear wheel bearings
2002 SUZUKI XL7
12,600 MILES
BETTY1946
  • 6 POSTS
Repair shop could not remove the hub. They beat on it and knocked off the studs. THey wanted to tap the axle over to knock out the hub, damaging the rear end. Is there a clip holding the hub on?? What is the easy way to remove the hub. I need to put in new bearings.
Jul 3, 2013 at 8:11 AM
KHLOW2008
  • 41,814 POSTS
Do you mean you can't take the drum off?
Jul 5, 2013 at 8:53 AM
BETTY1946
  • 6 POSTS
All I know is the hub has the bearing in it. It is supposed to be removed and taken to the machine shop to have them press out the bearing and press new bearing in. I think the drum is part of the brake. I think part of the brake has to be loosened to get to the hub. I have been trying to get a diagram to show me how this section looks and is put together but cannot get one yet. I guess I will have to purchase the Suzuki Manuel. I don't know that I trust the car repair people right now. I think my nephew who is a good mechanic could do it if he could find out how to get the hub off. He did try to do it but knew he did not know how. THen I took it to the repair shop. It seems they could have found out how to remove the hub. I still don't understand why they didn't know how to do it. Beating on something is not the way to go and ruining the rear end and axle sounds wrong to me too. I have to figure out something soon as the problem has to fixed soon. There may be a real big difference in a foreign car and a domestic car. Thank you for responding.
Jul 6, 2013 at 10:26 AM
KHLOW2008
  • 41,814 POSTS
The hub is held in position by retaining nuts that has to be removed before it can be taken off the axle.
Jul 6, 2013 at 12:21 PM
BETTY1946
  • 6 POSTS
I was told that there is a clip holding the hub on on my Suzuki. I don't know why the repair place did not know how to get the hub off. They beat the studs off and still could not remove the hub. I am hoping the Suzuki place knows how but I am afraid to take it to them also. I am waiting now to get enough money to try to get it fixed again. Thanks for responding.
Jul 6, 2013 at 8:14 PM
KHLOW2008
  • 41,814 POSTS
Information is rather vague in our database and here are the procedures.
REAR AXLE SHAFT
Removal
1. Remove rear brake drum. Drain gear oil from rear axle housing by loosening drain plug. Remove rear wheel bearing retainer nuts from axle housing. Remove wheel speed sensor from rear axle housing (if equipped with ABS).
2. Ensure there is clearance between rear wheel bearing retainer and parking brake shoe lever. If there isn't clearance, loosen cable locking nut further to obtain clearance. Using a brake drum remover and a slide hammer, draw out axle shaft.
3. On vehicles equipped with ABS, remove sensor rotor from retainer ring. Use a grinder to grind one part of the sensor rotor until it is thin. Use a chisel to break sensor rotor and remove.
4. To remove bearing retainer ring from axle shaft, grind bearing retainer in 2 places and use a chisel to break retainer ring.
5. Remove retainer ring from shaft. Remove bearing from shaft by using a hydraulic press. Remove wheel studs using a hydraulic press.
Jul 7, 2013 at 3:40 AM
BETTY1946
  • 6 POSTS
Thank you for your response. I will show this to my Nephew. He can make sense of it. He had told me he thought you had to drop the axle. I stll can't figure out why the car shop would not listen to me or find out how to work on a foreign car. It is different than a domestic. car. Thanks again.
Jul 7, 2013 at 4:42 PM
KHLOW2008
  • 41,814 POSTS
You're welcome.
This should be similar for most makes. The axle ahft is held in position by nuts but removing them do not necessarily mean it would come off easily. The procedures indicates the necessity to use a slide hammer to pull the shaft after removing the holding nuts.
Jul 8, 2013 at 7:14 AM
BETTY1946
  • 6 POSTS
Thank You
Jul 8, 2013 at 6:27 PM
KHLOW2008
  • 41,814 POSTS
Any update on this?
Jul 14, 2013 at 6:20 PM
BETTY1946
  • 6 POSTS
Not yet? Haven't been able to find out if any mechanic here knows how yet??? Thanks
Jul 15, 2013 at 7:37 AM
KHLOW2008
  • 41,814 POSTS
Any update on this?
Sep 14, 2013 at 9:42 PM
