Replacing serpentine belt, complete diagram and instructions needed?
2008 HONDA ODYSSEY
220,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
YIKAI CAO
MEMBER
FOLLOW
I need the correct diagram of the belt and exact location of bolt to release tension.
Dec 20, 2023 at 10:42 AM
CERTIFIED EXPERT
Sure, here are the instructions on how to replace the serpentine drive belt on your vehicle with the belt routing as well. Check out the images (below). Let us know if you need anything else.
Dec 21, 2023 at 2:02 PM
YIKAI CAO
MEMBER
Where is the location of the bolt to release stress of belt? Is it in the center of the tension wheel?
