This will not be easy as the system is always set to default and the light will come on. Disconnecting fuses will not do it as other systems are tied into the fuses as well.
The only way to do it is to remove the cluster and remove the bulb. There will always be codes set for the suspension.
I attached the procedure and some pictures for you.
INSTRUMENT CLUSTER
Removal and Installation
All vehicles
CAUTION: Electronic modules are sensitive to electrical charges. If exposed to these charges, damage may result.
1. NOTE: Prior to removal of the instrument cluster, it is necessary to upload the instrument cluster configuration information to the diagnostic tool.
Depower the supplemental restraint system.
2. Remove the instrument panel finish panel.
Expedition
3. Remove the screws and pull the instrument cluster out from the instrument panel.
4. Remove the instrument cluster.
Press the retaining tabs, remove the transmission range selector, and position aside.
Disconnect the electrical connectors.
Navigator
5. Remove the 4 screws and pull the instrument cluster out from the instrument panel.
6. Disconnect the electrical connectors and remove the instrument cluster.
All vehicles
7. To install, reverse the removal procedure.
Download the instrument cluster configuration information from the diagnostic tool into the new instrument cluster.
Nov 25, 2020 at 4:27 AM
