You would need to have the system evacuated first before you do any repairs on the A/C system since the system could be under pressure. Also replace the drier and expansion tube if the compressor has failed internally and flush the system.
Remove or Disconnect
Negative battery cable at battery.
Recover refrigerant.
Remove serpentine belt.
Raise vehicle.
Right air deflector and splash shield.
Electrical connections at the compressor.
Compressor/condenser hose at rear of compressor and discard seals.
Compressor attaching bolts.
Compressor.
Drain and measure compressor oil.
Install or Connect
Drain compressor oil from new compressor.
Refill compressor with same amount of oil drained from old compressor. If less than 30 ml (1 oz.) was drained from old compressor add 60 ml (2 oz.).
Compressor and compressor attaching bolts.
Tighten
Bolts to 58 N.m (43 lb ft) Front
Bolt to 50 N.m (35 lb ft) Rear
Important
Any repair to the A/C compressor or the A/C belt system will require loosening some A/C bracket bolts. To prevent future torque loss after re-tightening of these bolts, the bolt or stud should be replaced with an appropriate new bolt or stud OR apply Loctite(R) 242 or equivalent to the bolt or stud threads. Follow the package instructions for best retention.
Compressor/condenser hose to rear of compressor using new sealing washers (not required to be lubricated).
Tighten
Bolt to 33 N.m (24 lb ft) .
Electrical connections to compressor clutch.
Lower vehicle.
Serpentine belt.
Negative battery cable.
Tighten
Bolt to 16 N.m (12 lb ft) .
Evacuate, charge, and leak test A/C system.
Hope this helps.
Jun 4, 2017 at 2:27 PM
