Does this car have a turbo?
P2183 - Engine Coolant Temperature Sensor 2 (ECT2)
There are two sensors, on is the cylinder temperature sensor, the other a coolant temp sensor. ECT2 is at the radiator outlet (lower hose/outlet tank). ECT2 helps the PCM manage fans, thermostat strategy, and grill shutters.
Clear the codes once completed and you should be good to go, these sensors have a high failure rate FYI. Let us know if you need anything else.
Oct 15, 2025 at 9:29 AM
