persistent Cylinder five Misfire
2005 CHEVROLET IMPALA
110,000 MILES • 3.8L • FWD • AUTOMATIC
THISAUTOROOKIE
  • 20 POSTS
I am in the process of rebuilding my engine after having persistent cylinder five misfire, I replaced everything relating to the Cylinder five, But to no avail. So when I opened it up, I found oil on top of the lower intake manifold, seems a common issue with these engines. My throttle body to upper intake manifold gasket looks warped from the EGR tube heat (which I suspected is where the coolant was getting to the oil from)
I provided a link at the bottom of a video that I uploaded, In that video, my rockers and push-rods have play in them, (the rockers slide from side to side, even tho its not very much, but it worries me, also, I can spin around some of the push-rods with ease especially cylinder number five push-rods), I have not gotten to the rear bank Yet, but I am guessing it will be the same scenario back there.
I though of just replacing the lifters and corresponding push-rods that had play in them (as a cheap fix), but I figured that would not be a good idea.
So my question(s) is, are the play that I am having in those rockers and push-rods a common thing to see in these engines?
If not : (1) what would be a good way to diagnose what my problem is while I have the engine open?
(2) What extra step/check can I do while I am inside the engine to see what else I need to perform a good fix? Is it worth is dropping the oil pan and checking the bearing for any play?
And (3) If I do not need anything else, will just replacing the push-rods and lifters fix this issue for me?
Thanks.
Link to Youtube Video : https://www.youtube.com/watch?v=LYh8oXtdWA0
Sep 15, 2016 at 10:27 PM
CARADIODOC
  • 34,306 POSTS
The first step should have been to perform a cylinder leakage test. You can still do that if the cylinder heads have not been removed. Check at an auto parts store that rents or borrows tools to see if they have the tester. It is used with compressed air. That is usually performed after or in place of a compression test. It will identify four different sources of cylinder leakage.
GM has had a real lot of trouble with elusive misfires being caused by mismatched fuel injectors. Most manufacturers buy their injectors in flow-matched sets. GM has a large bin full of injectors and they just grab a bunch on the assembly line and stuff them into the engine with no regard to flow-matching them. At higher mileages, one will start to flow a little less fuel than the rest resulting in a lean misfire. The easiest way to find that is to switch two injectors, erase the fault code, then wait to see if the misfire code sets for the same cylinder or the one you moved the suspect injector to.
You had better be able to spin the push rods. That rotating in operation promotes even wear on the tips and their mating surfaces. The ones you wont be able to spin with your fingers are those that are holding the valve open.
Be aware that moving parts develop a wear pattern that matches mating parts they contact. That is why it is critical to reinstall those parts in the same places they came from. That pertains to rocker arms and push rods, and push rods and lifters. Those two aren't that hugely important, but if you plan on replacing lifters, (which don't sound like they're needed), you must replace the camshaft too. The bottoms of the lifters wear to match the lobes on the camshaft. For that reason you will usually find the lifters and camshaft sold as a complete set.
Hydraulic lifters will bleed down in about twenty seconds when they have sustained pressure on them from a valve spring. That is how they adjust when push rods expand and get longer when the engine warms up. If one were to not bleed down, you would develop a noticeable misfire when the engine got warm. You need oil under pressure to pump the lifter back up while it is being stroked by the camshaft. That means it wont pump up when you turn the engine by hand. That is where you will see a real lot of play in the push rod. Most lifters also have an internal spring to help keep them extended, but you can easily overcome that with heavy thumb pressure on the rocker arm.
I suspect you have gone too far into the engine, and nothing you have said so far suggests the need to tear into lower engine bearings. Those are very low failure items so i would leave them alone until there are symptoms that suggest otherwise. Put your time and effort into sealing the intake manifold. When you are done, see if you can rent a smoke machine to double-check your work. That will let you inject a white, non-toxic smoke at 2 PSI into the oil dip stick tube to see if any smoke sneaks out through the throttle body, (intake manifold), or spark plug hole. Also consider adding a small bottle of dark purple dye to the oil. If oil is leaking into the intake manifold, the dye will show up as a bright yellow stain at the tail pipe when viewed with a black light. Auto parts stores will have the dye for the fluid being tested, and they should have a black light too.
Sep 16, 2016 at 12:40 PM
The play you see is normal. I would do a compression test before taking the engine part. I would also check to see if you have a flat camshaft, turn the engine over and watch the movement of the rockers.
Here is a guide that will help you.
Please let us know what you find so it will help others. Thanks for the video, it really helped.
Best, Ken
Sep 16, 2016 at 1:01 PM
THISAUTOROOKIE
  • 20 POSTS
Hello everyone, My main mission now is to at least have the car started, Even if the Misfire returns, but let the car at least start up/Run. I have changed the Upper and Lower Intake Manifold Gaskets, But Car Still won't start.. What else is preventing the car from starting?
Jun 22, 2017 at 5:02 AM
THISAUTOROOKIE
  • 20 POSTS
Also, I Want to know where a puff of smoke came from Couple of times when I was Cranking the Engine for a long time, Maybe that'll help Me in figuring this out... The smoke came from Behind the Engine, what is around/Back there that can Produce smoke?
Seems a typical place where the car catches fire from..
Thanks.
Jun 22, 2017 at 5:05 AM
It sounds like you have a crankshaft angle sensor that has gone bad. Here is a guide that will show you what you are in for when changing the sensor out.
and some diagrams on what it will be like on your car. (below)
Jun 24, 2017 at 12:11 PM
