Need help with reverse light bulb and engine.
2002 VOLKSWAGEN GOLF
SONI123
My reverse lights don't seem to work and I wanted to know how I would know if it is blown out. Also, How do i know if my oil in mixing with water. As when i open the oil screw it is yellow however, i've cleaned it and it seems okay but what does that mean? Or is it simply just fluid to protect the engine. Thanks.
May 31, 2013 at 5:11 AM
DOCFIXIT
  • 18,828 POSTS
OHM meter to check bulbs or replace with nwe as for oil what you see in filler cap is normal condensation due to short drive cycles
May 31, 2013 at 8:38 AM
EXOVCDS
  • 1,883 POSTS
Standard or automatic? I have never had an issue with automatic reverse light switch.
The standard transmission reverse light switch (2 wire) is a common failure item with age... the wiring also like s to break with age.
Thomas
Jun 1, 2013 at 2:19 PM
DOCFIXIT
  • 18,828 POSTS
What happened?
Jun 4, 2013 at 8:38 AM
