After valve gasket replacement oil leaks out when car is started
2012 BMW X5
100,000 MILES
DANIE1481
My fiancé changed the valve cover gaskets on my car and now it spills all the oil out when started and would not go into drive. What did he do wrong?
Dec 7, 2019 at 6:41 PM
SCGRANTURISMO
  • 4,897 POSTS
Changing a valve cover gasket is one of the easiest gaskets on an engine to change. The valve covers are on the top of the engine and are usually very accessible. If the gasket was not properly seated, it would definitely leak oil out it, but it would not cause the vehicle to not go into drive. That would have to do with the transmission, which is a totally different part of the vehicle all together. What exactly do you mean when you say that it wouldn't go into dive?Please be specific, the more specific the better.
Thanks,
Alex
2CarPros
Dec 8, 2019 at 5:37 PM
