My son lost the car key, so my friend decided to knock out the Ignition with a screwdriver and he messed it up and it won't start or set off the security. It has pass lock 2. So, the sensor is in the steering column not in the key. He also damaged the switch, so I ordered another switch and installed it and called it and tried to start it with a screwdriver and it still wouldn't start. I read online about how to bypass security systems with a resistor. And I tried it but no luck, so I got an entire steering column power steering column from a junkyard, it's the wheel and column it's about 2' long. My question is, how do I install it I've got the steering wheel and the airbag off? Can't I just replace the Ignition housing that has the sensor in it? I just don't want to mess up the steering when all I have to do is replace the housing. Please help my daughter is disabled and I have to get her to school.
Aug 7, 2022 at 11:34 PM
