Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Dodge
Avenger
Ignition
Distributor
Pick Up Coil
need help ground signal to coil not pulsing
1998 DODGE AVENGER
230,000 MILES • 2.0L • 4 CYL • FWD • AUTOMATIC
CODY WALLACE
MEMBER
1 POST
FOLLOW
Only cyliner one and three have spark, two and four do not.
May 17, 2016 at 11:13 AM
WRENCHTECH
CERTIFIED EXPERT
You need to test the wires all the way back to the PCM. If the signal is npt coming out of the PCM, then the PCM is bad.
May 17, 2016 at 12:12 PM
