Okay, i don't have much hair left trying to figure this out out. I have the car listed above GT model turbo. Has a code po304. Has no ground pulse on # 4 injector. Has good positive power at the side of injector. Has good flash at other injector i have sent the PCM back to a repair shop twice. They said both times the number 4 driver was good, but the second time they said they replaced the driver as a courtesy. Still no noid light pulse on 4 i have even went and cut the 4 wire. At PCM and put a wire to the negative side. Still the. Same. Then even got a very very thin wire. Put it over the PCM term that is the # 4 negative driver. Still no pulse any any ideas?
Apr 28, 2019 at 1:54 PM
