Intermittent TCC solenoid
2002 NISSAN PATHFINDER
200,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
JOSHDAVISON218
Can an intermittent TCC solenoid cause other codes like knock sensor 02 sensor and catalytic converter below threshold? What's the best way to go about trying to fix it without going broke?
Mar 29, 2019 at 2:46 PM
SCGRANTURISMO
  • 4,897 POSTS
The answer is no. Your Malfunction Indicator Lamp (MIL) AKA, "check engine light" is illuminated and you pulled Direct Trouble Code (DTC) p0430. This is a DTC for your vehicle's catalytic converter operating below it's useful threshold. The remedy for this DTC is to have your catalytic converter replaced.
Catalytic converters are not terribly expensive, you can get a new one on eBay or Amazon for around $75.00. If you live in California the price will be a little more around $100.00 for a CARB (California Air Resource Board) compliant catalytic converter. To install it you will need to get your vehicle up on jack stands. Here is a link with a guide to help you with this if needed:
You will need a sawsall, rotary cutoff tool, or a hacksaw and two muffler clamps. Make sure to get muffler clamps that are the same size as your vehicle's exhaust. With your vehicle safely secured cut out the bad catalytic converter. On the new catalytic converter cut a inch incision on each end of the opening as if it were standing on end and you were cutting towards the middle. Make another a right angle so if the catalytic converter was standing on end it would make an "x" or you cut a pie into four equal pieces. Do the same on the opposite end. Put a muffler clamp on one side of the exhaust pipe and the other one on the other exhaust pipe. Slide the catalytic converter onto the exhaust pipe where the old one was with the converter tube on the outside. Now slide the muffler clamps over the catalytic converter ends and exhaust pipe and tighten. That's it. Your done. Get back to us and let us know how it turns out.
Thanks,
Alex
2CarPros.
Mar 29, 2019 at 4:35 PM
JOSHDAVISON218
It's throwing code p0744 as well. what could that be?
Mar 30, 2019 at 1:31 PM
JOSHDAVISON218
As well as knock sensors for cylinder one?
Mar 30, 2019 at 1:32 PM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
There is no knock sensor for cylinder one. Knock sensors are generally one per engine, or high performance engines will have one per bank, but none have one per cylinder. Knock sensors work by detecting a sudden "jolt" that happens when detonation happens in an engine. Detonation or "knock" happens when the air fuel mixture in a cylinder of your vehicle spontaneously combusts with being detonated by the spark plug. This happens when the piston is still on it's compression stroke coming upwards in the cylinder. The "knock" that you here is the flame front of the air fuel detention, which has now gone off like a stick of dynamite, slapping the piston on it's upward stroke. Detonation (knock) can be extremely damaging to internal engine parts and must be dealt with.
Knock sensor are made from a piezo electric material that generates electrical current when a sudden jolt goes through it. When your vehicle's Power-train Control Module (PCM) AKA, "computer" gets an electrical signal from the knock sensor, it retards the engine timing to bring your vehicle away from detonation. There are several things that can cause detonation such as, timing to far advanced, combustion chamber heat, too high of a compression ratio, gasoline octane rating too low. Did you know that premium gas will not make your vehicle run better, burn cleaner or anything like that. 93,89,87 is the octane rating of gas. Gas is gas is gas and will all burn the same.The octane rating goes like this. If 97 octane gas was broken into a 100 parts, 97 would be octane which is 100% resilient to self detonation under compression, and 13% heptane which is completely unresistant to self detonation under compression. The same goes for 89 and 93. If you look at the pump it will have this formula for how the octane rating was determined. R+M/2. This stands for real world plus machine shop dived by 2. The gas is run in a real world engine and one in a machine shop and the octane rating is an average from both. So, anyone who buys 93 octane gas thinking it will make their vehicle run faster is simply throwing away their money. 87 octane will work exactly the same. I have to rum 93 octane in my car but it is a supercharged mustang GT with the compression ratio upped to 10:1. The volumetric efficiency of the cylinders is well over 100% and it is prone to self detonation.
Anyway DTC P0744 is in association with the transmission TCC Solenoid. I have included a description of it in the diagrams down below.
Thanks,
Alex
2CarPros
Mar 31, 2019 at 12:43 AM
