Can I get vacuum and wiring diagrams?
2006 MAZDA 3
207,000 MILES
ANDIWARD76
  • 10 POSTS
Someone "worked" on my vehicle and now I need vacuum and wiring diagrams to fix what they messed up. Is there any chance you can get me those?
May 30, 2023 at 10:45 PM
I would be happy to help. Is it possible to get the engine size? I need to know if it is a 2.0L or a 2.3L. Also, let me know what wiring schematics you need. (Which circuits are you looking for)?
joe
May 31, 2023 at 10:26 PM
ANDIWARD76
  • 10 POSTS
That's the thing. When it comes to the engine size, the door tag says its a 2.3L but everything else says it's a 2.0. How do I know for sure?
Jun 2, 2023 at 11:58 AM
There should be a label under the hood indicating the engine size. Also, does it say anything on the valve cover itself?
If possible, let me know what the 8th digit of your VIN is. That identifies the engine that the vehicle came with. Unless it was replaced, it should be correct.
I attached the VIN breakdown. Take a look.
See pic below.
Jun 2, 2023 at 7:49 PM
ANDIWARD76
  • 10 POSTS
Here is the info I have at the moment. Hopefully this will give you some clarity?
Jun 2, 2023 at 8:17 PM
According to the VIN (engine code F), you have a 2.0L with federal/Canada emissions. Does that sound correct?
As far as the tag on the door, was the vehicle ever in an accident, and had that door replaced with a used one? That's the only thing I can think of.
I attached the vacuum schematics for your vehicle below. Let me know if that helps. Also, I need a circuit for the wiring needed.
See pic below.
Jun 3, 2023 at 8:50 PM
ANDIWARD76
  • 10 POSTS
Can you get me the intake Manifold runner solenoid line diagram?
Jun 4, 2023 at 2:20 PM
I attached the entire powertrain management system schematics below. I highlighted the wiring related to the runner.
Let me know if this helps.
See pics below. Note: The schematic was 4 pages long. I had to cut each pic in half to make them readable.
Jun 4, 2023 at 9:56 PM
ANDIWARD76
  • 10 POSTS
These are perfect. Thank you so so very much.
Jun 4, 2023 at 10:34 PM
You are very welcome. When you have a chance, let me know how things turn out for you or if I can help.
Jun 5, 2023 at 7:19 PM
