I need help on how to get my temperature gauge working please.
May 29, 2019 at 10:04 PM
CERTIFIED EXPERT
Good morning,
There is a sensor for the engine temperature on the front of the driver's side head.
I attached a picture for you to view. This is the most common reason for the gauge not working.
Image (Click to enlarge)
May 30, 2019 at 3:24 AM
JEFF HILL
MEMBER
Okay, but when I plug my scanner in to the OBD2 diagnostic connector it reads the engine temperature. That's why I thought the cht sensor was okay and it had to be the ECT on the intake it has both?
May 30, 2019 at 5:09 AM
CERTIFIED EXPERT
If it is reading engine temperature on the scan tool, then you either have wiring issue from the ECM to the dash or the cluster is bad.
May 30, 2019 at 1:32 PM
JEFF HILL
MEMBER
I tried a used cluster that was working in the other truck and it didn't fix problem. then I jumped the two wires at the engine cooling sensor and the gauge pegged to hot so I assumed the wiring was okay.
May 30, 2019 at 7:45 PM
CERTIFIED EXPERT
Change the coolant sensor.
May 31, 2019 at 2:44 AM
JEFF HILL
MEMBER
I did replace the ECT twice one from Rock Auto and One from NAPA and the plug wire to and tested the red with white wire it has 10 K oms.
May 31, 2019 at 7:28 AM
JEFF HILL
MEMBER
The yellow and red wire is it the ground wire?
May 31, 2019 at 7:31 AM
CERTIFIED EXPERT
No, neither are grounds. The sensor has 5 volts going to it and the other is a return signal wire to the PCM. Then the PCM sends a signal to the dash for the gauge.
Do you have a scan tool that can read engine temperature?
May 31, 2019 at 8:18 AM
JEFF HILL
MEMBER
Yes I do. But what is the voltage for red with white wire at ECT sensor unplugging with key on. And same question for yellow with red wire?
May 31, 2019 at 8:41 AM
JEFF HILL
MEMBER
I know I need to test wiring from PCM to gauge cluster, but have no information on test procedure and no information for pin location for connector at PCM and gauge cluster.
May 31, 2019 at 8:50 AM
CERTIFIED EXPERT
Okay, I attached a diagram for you to view.
This is not something you can test with a voltmeter. The only thing you can do is to check the connector at the back of the cluster. The controls for the gauge are in the solid state unit in the cluster.
May 31, 2019 at 12:38 PM
JEFF HILL
MEMBER
Can you please send me a clear copy or a link that I can see or download? thanks, Jeff
You have helped me, but I need a complete image of cluster wiring.
Jun 1, 2019 at 8:13 AM
CERTIFIED EXPERT
That is the only image of the cluster. As I stated before, there is nothing you can check internally as it is controlled by a microprocessor in the cluster itself.
Jun 1, 2019 at 8:16 AM
JEFF HILL
MEMBER
Okay, thank you for your time. I just was hoping for a link or a web sight that I could look up images on my own.
Jun 1, 2019 at 8:45 AM
CERTIFIED EXPERT
You could go to Alldata.com and get a one day pass or longer and get all the information you want. Well worth it.
Jun 1, 2019 at 11:38 AM
CERTIFIED EXPERT
Did you respond? I got a notification but no response.
Jun 2, 2019 at 5:34 AM
JEFF HILL
MEMBER
Thank you, but I don't have a credit card.
Jun 2, 2019 at 6:18 AM
CERTIFIED EXPERT
There is no charge for anything in our site?
Jun 2, 2019 at 6:29 AM
JEFF HILL
MEMBER
No about getting Alldata for a one day trial, but thanks for your help.
