Need a wheel alignment badly
2004 DODGE STRATUS
180,000 MILES • 2.4L • 4 CYL • AUTOMATIC
CRAIGBIRNIE5
But every shop I talk to denies it due to control arm issues. The front ones got replaced but the left rear is bad. So can they do just a front end alignment? I am low on money after the front ones were replaced.
May 13, 2019 at 10:08 AM
Hi Craig,
Yes. They can do just a front wheel alignment but if the rear arm is bad enough that multiple shops have declined to do it, I would just save up the money to get the rear done. The reason they are declining to just do the front is because it is actually a waste of money. Once they do they front and then the rear is so far out, that will throw your alignment off while you are driving down the road. Plus, when they go to do the rear arm they will need to completely redo the front alignment as well.
I would suggest just waiting and driving as little as possible until you can correct the rear and align it one time. You want to try and limit your driving because you don't want to damage your tires to the point that they need replacing.
Sorry I don't have a better answer for you.
May 13, 2019 at 6:37 PM
CARADIODOC
  • 34,306 POSTS
Some specialists will adjust just the front wheels, but most will not. All cars today get a "four-wheel-alignment" even when the rear wheels are not adjustable. That's because the computer looks at the direction the rear wheels are steering, then has the mechanic set the front wheels to match them to insure the steering wheel is straight. If a rear wheel is allowed to turn a little due to a worn part, it is going to affect the steering wheel position.
That changing steering wheel position is going to be minimal and probably not noticeable, but there's two things the mechanics and shop owners are worried about. The first is once the front wheels are aligned, you aren't going to notice a problem with handling or steering control, so you won't come back to have the work done on the rear. That leaves you out there with a false sense of security, less-than-perfect tire wear, and less-than-perfect handling. Performing just half the alignment means they're putting their stamp of approval on your car that it is safe to drive.
The second problem is if you're in a crash after the other guy runs a red light, his lawyer or insurance investigator is going to find the worn part along with any other worn parts or modifications to your car that affect handling, braking, and steering response. They will use that to convince a jury that you were partly at fault for the crash because you were less able to avoid it, and they might be right. At this point the shop that did half the job becomes a party to that lawsuit. It's that threat of lawsuits that are on the minds of all mechanics and shop owners every time they work on a car. They can even be taken to task for a defect on a car that has nothing to do with what is was in the shop for. If they don't point the problem out to you, they can be held liable in some states if it causes a problem later. If they do point out the defect, they run the risk of being accused of trying to sell you parts or services you don't think is needed.
While those problems sound serious, the more general concern is they're taking your money for an alignment, and in return you expect the car to go straight, corner smoothly and predictably, and it should have good, even tire wear. Those expectations can not be met when a worn suspension or steering part is on the car, therefore, they're taking your money for a service they know they can't deliver. It's the less-than-reputable shop that will gladly do the alignment on your car with a worn part.
May 13, 2019 at 7:09 PM
