hello guys need help with my navara 2002 3.0l diesel turbo. she is struggling in 5th gear to climb above 2000-2500 revs 1st to 4th gear is fine, however only recently during a trip in australia for 2 hours i noticed that on the return journey the car was struggling in 5th gear... i am due to change the fuel filter tomorrow hoping that this will clear the problem... is there anything else i should look out for? the engine is also a recon should i add with 2,000miles on. it was serviced only 2 months ago with fresh oil filter and fresh air filter, just never changed the fuel filter... hardly use the ute just gets a run on the weekends and on the odd day... i have also heard that there is a micro filter in the primer pump somewhere that should be cleaned?
Thank you in advance
David
David
Oct 25, 2015 at 5:27 AM
