The battery is not charging even though the alternator tests good. I have replaced the battery (though it is starting to fail again from occasional driving without an alternator) and checked for continuity between the positive terminal of the alternator and battery. I have also checked the relevant fuses (9 and 11) and tried switching what I believe is the bulb check relay (closest to the front on the passenger side of the engine compartment. Tell me if I'm wrong here.) with another nearby relay with the same number on it. I have also checked for corrosion on the sockets for the relays and fuses.
The charge light bulb tests good, but never lights up, except very dimly in the following scenario:
Sometimes, maybe 1 in four times, when i turn the engine from the on position back to accessory, the indicator lights will not turn off, except for the airbag light, which then turns back on after a few seconds along with a slight dim glow which slowly creeps into the battery light.
I have also noticed that when I disconnect the alternator, the yellow/black wire shows a voltage to the + terminal of the battery when the car is off, and a voltage to the - terminal when the key is turned on. This led me to check for continuity to the opposite battery pole in each case, and I found 13 ohms to - in the off position but no continuity to either pole in the on position.
I feel like I might have hooked jumper cables up backwards in the dark like a silly billy but am not 100% sure about that memory as I was very sleep deprived at the time. Is there a fried diode somewhere? I'm baffled.
Oct 6, 2020 at 2:34 PM
