Windshield wipers do not turn off with the switch
2003 NISSAN ALMERA
150,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
OKOLUDU STEPHEN
  • 4 POSTS
If I put on my wipers, I try to put it off when screen has been cleaned. But wipers will not stop until I switch off ignition. What's the fault?
Feb 26, 2020 at 4:08 PM
If you can not turn the wipers off, it sounds like either the switch or a relay issue. I apologize but this vehicle isn't offered in the US, so my technical information is very limited.
Check the wiper relay. Here is a link showing how to test a relay:
Here are a couple links you may find helpful:
The relay can be either under the hood or in the passenger compartment. Let me know if you have questions and what you find.
Feb 26, 2020 at 4:32 PM
