my van is leaking water and or coolant from I between the flywheel and transmition
1998 CHRYSLER TOWN AND COUNTRY
V6 • FWD • AUTOMATIC
KORIJAMES36
  • 4 POSTS
Took off the fly wheel drive plate cover and is coming from there some where when I put water in the radiator it goes right through onto the ground
Dec 7, 2014 at 3:32 PM
WRENCHTECH
  • 20,761 POSTS
If it's truly coming from inside the bell housing, then it would likely be a bad freeze plug but make real sure it isn't leaking from the valley pan above and running inside the housing.
Dec 7, 2014 at 4:13 PM
KORIJAMES36
  • 4 POSTS
Where is the valley pan located
Dec 7, 2014 at 5:17 PM
KORIJAMES36
  • 4 POSTS
Does the transmission have to come out to replace the freeze plug
Dec 7, 2014 at 5:20 PM
WRENCHTECH
  • 20,761 POSTS
It would be under the intake if it has one but I can't tell you how it's set up because you never listed the engine that it has. Anything leaking near the back of the engine would run down in that direction.
Dec 7, 2014 at 5:21 PM
WRENCHTECH
  • 20,761 POSTS
Yes, on the transmission.
Dec 7, 2014 at 5:22 PM
