My undercarriage plastic is loose and I hear noise every time I make a turn it is a clicking sound
2004 TOYOTA CAMRY
240,000 MILES • 6 CYL • 4WD • AUTOMATIC
LMG
My car was making this clicking sound every time I make a turn and the undercarriage plastic cover is loose and dragging the ground. I do not know if that I is the problem or not. Now today the click noise is occurring even when I drive on straight road and my steering wheel feels like it is wobbly. Car is pretty old with a ton of miles, and trying to hold on to it a while longer. What do you think the problems are? Please advise.
Jan 28, 2015 at 10:23 AM
Good evening,
It does sound like a CV joint that is failing. You need to have them checked and see if the boots are damaged or gone.
https://www.2carpros.com/articles/how-a-cv-joint-works
https://www.2carpros.com/articles/symptoms-of-a-bad-cv-axle-joint
They will have to be replaced.
https://www.2carpros.com/articles/replace-cv-axle
As far as the plastic, that is a dust shield. You should have it removed or repaired to sit securely.
Mar 30, 2020 at 4:15 PM
