I have already replaced thee fuel pressure sensor with Bosch OE exact replacement (the "blue" o-ring).The Bosch p/n is what you get when you search with the Volvo part number.
I've driven the car about 80 miles after the replacement and the OBD tester still shows the P0190 "Stored" trouble code. The tester shows the car's computer is showing about 82 psi fuel pressure. You can't reset a "stored" trouble code with the OBD tester.
That's the only trouble code. I've seen some comments in the Volvo blogs that the MAP sensor is causing the trouble code.
Oct 21, 2019 at 4:42 PM
