Hello, I'm Danny.
It sounds like you just lost the reverse clutch pack. That will require the removal of the transmission and a complete rebuild. You might also want to see if your local auto wrecking yard might have a used one hopefully with a small warranty. Rebuilding your transmission is roughly $1,000.00 to $2,000.00 depending on your area/type of shop you go to. Hope this helps and thanks for using 2CarPros.
Danny-
Oct 13, 2019 at 6:08 PM
