Transmission only has drive and park
1995 PLYMOUTH ACCLAIM
92,741 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
ALEBCODY60
Reverse tries to go forward sometimes and neutral through first is nothing but drive. I bought a transmission control solenoid but do not know where to install it at.
Feb 9, 2018 at 5:36 PM
CARADIODOC
  • 34,306 POSTS
The solenoid pack is on the front of the transmission, right above the pan, and under a rubber cover.
It is unlikely that is going to solve the issue. Have you had the diagnostic fault codes read and recorded? You will need to find a mechanic with a scanner that can access the transmission computer to read those codes.
Feb 9, 2018 at 7:05 PM
