Intermittent check engine light and engine putters
2007 LEXUS ES 350
75,000 MILES • 1.6L • 6 CYL • 2WD • AUTOMATIC
JAYLEENWLB
Check engine light flashes sometimes and when it does it sounds like something clears out and the car takes off smooth. Other times, she putters. Still drives, but I don't know what is wrong. I use premium gas, but I am overdue for oil change.
Nov 13, 2021 at 12:04 PM
When this happens, does the check engine light flash on and off before turning off completely? If that is the case, it is an indication of a misfire. Often times it could be a simple spark plug or even an ignition coil.
What I need you to do is have the computer scanned for diagnostics trouble codes. This way we can narrow it down to the specific cylinder or cylinders causing the issue.
Here is a video showing how it's done:
https://youtu.be/-6SmUURn1ac
I realize most people don't own a scanner, but oftentimes, most parts stores will do it for free. If possible, have that done and let me know what is found.
Also, it is very important to keep the oil serviced on a regular basis. These vehicles have something called variable valve timing. It is controlled by oil pressure. Dirty oil can cause issues. So, it is a good idea to keep it clean.
Let me know if you are able to have the computer scanned and what codes are found. That way, I can focus on specific issues.
Take care and let me know.
Nov 13, 2021 at 11:11 PM
