Good morning,
You can either call a locksmith to come to you and make a new set of keys or replace the cylinder.
It would be easier to have the locksmith come to you.
I attached the procedure for replacing the lock cylinder as well.
If the cylinder does not turn, as you indicated, then you will need to drill out that pin.
Ignition Lock Cylinder Replacement
Removal Procedure
Important: The Vehicle must be in PARK prior to ignition cylinder removal.
1. Disconnect the negative battery cable.
2. Disable the SIR system. See: Air Bag(s) Arming and Disarming > Procedures
3. Remove the steering column trim covers. See: Steering Column > Removal and Replacement > Steering Column Trim Covers
4. Remove the park lock cable from the bottom of the housing.
5. Insert key into the ignition and rotate to the RUN position.
6. Depress the locking button through hole on side of ignition module assembly with a thin pick-type tool.
7. Rotate the ignition cylinder back from the ACC position.
8. Slide the lock cylinder to the ignition housing.
Feb 10, 2021 at 7:51 AM
(Merged)
