My gran-daughter had a local shop (one of these quick pull threw oil change shops), the invoice reflects that they drained the transmission fluid and replaced with 10 quarts of new transmission fluid. The car ran for about 2000 miles and then the transmission quit working, it is an automatic and now makes a terrible grinding noise when shifting and will not move the car. There was no transmission fluid when I checked it with the transmission dip stick.. I added 2 and 1/2 quarts on the side of the road where the car quit working..There is NO sign of any transmission fluid leaking under the car.. There is NO sign of transmission fluid spraying under the car..
Does this car take 10 quarts of transmission fluid on a normal fluid change? If the vendor did not add the transmission oil back after draining thru the drain plug, how far could you feasibly drive the car before the transmission would fail??
Jul 28, 2014 at 8:39 AM
