Front windows the actuator regulator clip came apart on both of them
2002 LINCOLN LS
164,000 MILES • 3.9L • V8 • 2WD • AUTOMATIC
STACYLYNN7
  • 32 POSTS
Actuator regulator clip came apart on both of them are the plastic ones. do I need to replace the whole window motor or just the clips?
Jun 11, 2020 at 7:42 PM
Hi Stacy,
I attached a pic below. Can you tell me which part has broken?
Thanks,
Jun 11, 2020 at 9:53 PM
STACYLYNN7
  • 32 POSTS
The two outer plastic clips on outsides’ or on top and bottom based on picture.
Jul 2, 2020 at 7:58 AM
Stacy, those are simply called window regulator attachment clips. They attach the glass to the regulator assembly.
Take a look at the pic below. If that is the part you are referring to, you can find them online or even eBay. They are cheap. Simply look up window regulator repair clips and it should bring it up for you.
Let me know if I can help in any way.
Jul 2, 2020 at 7:55 PM
