fan knob on the dash only works on high cannot adjust fan speed
2008 KIA SEDONA
147,000 MILES • V6 • FWD • AUTOMATIC
MARS9339
My fans for radiator and A/C are not turning causing my engine to overheat and A/C not working properly. The module is not working. where can I buy this part online?
Jun 5, 2017 at 11:15 AM
HMAC300
  • 48,601 POSTS
the cooling fan module is on rear for cooling fan assembly the cooling fan relay is also mounted there which could be bad. As far as fan for inside car there is no resistor so a mechanic will have to scan for codes as it can be the switch or control unit In car. But to make sure the cooling fan module is bad it must be scanned by a mechanic as well.
Jun 5, 2017 at 1:12 PM
