If there's no other symptoms, including loss of coolant, that is caused by condensed moisture build-up from excessive short-trip driving. The engine is not getting up to normal temperature to allow that moisture to vaporize and be pulled out by the PCV system. A good 30-mile run once a week at highway speed will eliminate most of that moisture.
Jan 15, 2020 at 2:20 PM
