It could be the tumbler or a switch issue. Do me a favor. Try lubricating the tumbler. Over time, they can get dirt in them leading to issues. Also, the steering lock can be positioned in a manner preventing the key from turning.
Take a look through this link. It explains different things to try, one of which is lubricating it. Also, make sure the key you are using is not worn and causing the problem.
https://www.2carpros.com/articles/ignition-switch-wont-turn-stuck
Let me know if that helps. If it doesn't we may need to replace the lock assembly. I attached the directions below in the event you want to do it.
Take care and let me know what you find.
See pics below.
May 15, 2021 at 9:07 PM
