It sounds like you could have a faulty crank position sensor.
When a crank sensor fails the engine will stall, regardless of if you are driving or stationary.
Over time the heat and vibration from the engine can make the crank sensor lose its calibration and it will send error codes to the ECM and the engine will be shut down.
Here are some helpful articles on crank sensor:
https://www.2carpros.com/articles/how-a-crank-shaft-angle-sensor-works
Sometimes a bad crank sensor will trigger the check engine light.
Is your check engine light illuminated?
Thank you.
Oct 7, 2021 at 2:56 PM
