I did a full bleed on my cooling system. Heat is in full blast and the most that is opened allowing coolant to go through the system. At first there was heat coming out of the vent (note) this is during the bleeding process. But when I took the car for test drive the heater stop working and there is no heat coming out of my vent. The temperature gauge pointed to high, but when I turn on to AC while I am driving the temperature gauged goes back to some what to normal. I did a pressure cooling system test and not leaks indication. I also did a combustion leak test and shows no leaks as well. It seems to me that the thermostat stop working while I am driving the vehicle because when I park back the vehicle the lower hose where the thermostat is not hot anymore but the other hose is very hot. I did pull out the thermostat the day before and test it by soaking it into a boiling water. Thermostat started to open and when I pour cold water it stared to close again. I cannot seem to figure out. Please help. Thanks
May 21, 2018 at 5:33 AM
