The water pump was replaced about 8 months ago and I wasn’t paying attention to the temperature gauge this morning until the car made a large thud noise and I lost power for a few seconds. It then would thrust and lose power each second until I was able to pull over where I found the hose attached to the temperature sensor and coolant reservoir had disconnected from both ends, coolant everywhere. When I got a tow truck, they had me turn it on to move it for them and it wasn’t making any noise and responded fine, but I’m very worried about potential heat damage. After I replace the hose, clamps and bleed the coolant to remove any air that could have gotten in the system, what should I look for? I don’t want to make things worse. The video was taken after I pulled it off to inspect before I turned it off (if it loaded, I’m not seeing it). Thank you in advance!
Mar 12, 2024 at 6:28 PM
