If the converter is new, then the o2 sensors are likely the issue.
Basically, the way this works is the downstream sensors are telling the PCM that the emissions have not been reduced to the proper amount, so the PCM thinks the converter is not doing its job.
This is normally a converter issue but if the upstream o2 sensor is not reading correctly and it is low, and the downstream sensor is reading correctly then the PCM would think that the converter is not reducing the emissions properly. Also, it can be reverse where the upstream is correct and the downstream is reading high incorrectly.
So, if you have a scan tool that can monitor the o2 sensors then that is the best way to determine this.
If not, then we should just replace all the sensors as we don't know if it is up or down stream that is causing the issue.
As for the C code. It is possible that this is causing that one, but we need to start with the o2 sensors and see if that resets.
If it does, then we need to get a new post started for it because that would not be related to this.
Dec 10, 2021 at 10:35 AM
