This could simply be an engine vacuum leak or the throttle body needing to be cleaned.
First, check to see if there are any leaks.
Here is a link that explains how it's done:
If no leaks are found, I would next check and clean the throttle body. If it is excessively dirty, it can cause a stall at idle.
Here is a link that explains how that is done:
I attached the directions for servicing the throttle body specific to your vehicle below.
Try these things and let me know the results.
joe
See pics below.
Jun 29, 2023 at 11:01 PM
