brakes are locking
1995 CHEVROLET TAHOE
300 MILES
MIKE950
When I turn right my brakes lock.
May 30, 2016 at 12:04 PM
CJ MEDEVAC
  • 11,004 POSTS
Brake Hose may be too short or installed with a twist in it?
Your turn
The Medic
May 30, 2016 at 12:32 PM
FIXITMR
  • 9,990 POSTS
how do you get them to unlock?
May 30, 2016 at 12:55 PM
FIXITMR
  • 9,990 POSTS
is ABS working?
May 30, 2016 at 1:00 PM
HMAC300
  • 48,601 POSTS
if the one side is locking then the other side is not working or there is some type of fluid like oil/brake fluid on rotor causing it. see if this helps , if it is frozen open bleeder screw it may have a bad brake hose as well.
https://www.2carpros.com/articles/car-pulls-right-or-left-when-driving-or-braking
May 30, 2016 at 2:00 PM
MIKE950
But it was not doing that before.
May 30, 2016 at 2:17 PM
CJ MEDEVAC
  • 11,004 POSTS
Yep, That is why you are here!
What about the ideas from HMAC300?
You are going have to do the tests/ checks and report back with your findings!
The Medic
May 30, 2016 at 3:09 PM
HMAC300
  • 48,601 POSTS
just because it did not do it before does not mean a part cannot go bad especially with a vehicle that is more than 20 years old. I still suggest you do the test that have suggested in the previous replies.
May 31, 2016 at 5:35 AM
FIXITMR
  • 9,990 POSTS
the most common cause of break lock is a restricted rubber brake hose. the restriction occurs because the little guide bracket that keeps hose from wandering rusts on the inside surface and squeezes hose shut. you can just pry it open some and relieve the blockage.
May 31, 2016 at 7:43 AM
Also if the brake caliper hose is twisted when the caliper was installed it can cause the brake to lock, ask me how I know lol
Jun 1, 2016 at 2:29 PM
