After installing the new battery in my vehicle listed above it starts but runs rough then shuts off with the Triangle display and message "Pull Over for Safety" and then shuts off. It has to be something simple since it ran just fine before replacing the battery. I also had Ford check the Hybrid battery's not too long ago and they said they were strong. I've already tried disconnecting the negative cable and letting it set then reconnecting and restarting but it does the same thing. Attaching a video.
Thoughts? Things to try?
Thank you,
Mike
Thank you,
Mike
Mar 16, 2025 at 8:44 AM
