Thanks for the image, yep you have a broken driveline, but I would raise the rear of the truck to see if the rear wheels will turn. It could be the driveshaft broke due to the rear differential issue, here is a guide that can help:
Here is a guide to help with the U joint replacement:
https://www.2carpros.com/articles/how-to-replace-a-universal-u-joint
If the rear wheels turn, I would service, the differential. This video will show you how, and you can look for metal in the gear oil:
https://youtu.be/6F26Kir0OCg?si=hpH62tS8CnpEAffs
Check out the images (below). Please upload pictures or videos in your response of any problems so we can see what to help you with.
Aug 17, 2024 at 10:28 AM
