A/C stopped blowing cold and the temperature gauge went to zero
2008 GMC ENVOY
160,000 MILES • 6 CYL
REDHULK
MEMBER
FOLLOW
Seems to be running fine but the A/C suddenly stopped blowing cold and the temperature gauge dropped.
Sep 19, 2019 at 10:07 PM
CERTIFIED EXPERT
Good morning,
I attached a wiring diagram for you to view. Check the fuses I circled for power on both sides with the key on. This is not a visual inspection, it is a voltage check on both sides of the fuse.
As far as the temperature sender, it could be a bad sender unit. Check the sender for power with the key on.
Sep 20, 2019 at 4:28 AM
REDHULK
MEMBER
didn't address the issue?
Sep 23, 2019 at 7:21 PM
CERTIFIED EXPERT
I do not understand what you mean? Please explain?
Sep 24, 2019 at 12:17 PM
REDHULK
MEMBER
Okay, so as i said the A/C quit blowing cold at the same time the temperature hand dropped to C. I drove the truck 10 miles home the next morning i drove about a mile and the temperature hand went from C to NORM then the AC started cooling again.
Sep 24, 2019 at 1:03 PM
CERTIFIED EXPERT
I was addressing the temperature gauge first as that will effect the A/C operation.
Sep 24, 2019 at 2:47 PM
REDHULK
MEMBER
Oh, okay then.
Sep 24, 2019 at 7:54 PM
CERTIFIED EXPERT
Let me know what you find. The 2 are connected.
Sep 24, 2019 at 7:59 PM
CERTIFIED EXPERT
The PCM ties these systems together I would do a CAN scan toy see what comes up you may have a bad PCM. Here is a video. You can get a CAN scanner from amazon for about $45.00:
