Four wheel drive is not working
2000 FORD EXPLORER
213,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
TOTO77X2
When I turn my switch for the four wheel drive nothing happens. No lights on the dash at all. What do I need to check?
Dec 13, 2020 at 1:24 PM
The way this works is the switch is turned and the GEM takes that request and engages the transfer case through the shift control module. Then it also tells the cluster that the switch state has changed.
However, we need to test what is coming out of the switch to start to find out where the issue is.
So I would go to the GEM module to start testing voltage. The GEM
on the Gray/Red wire sends power to the switch and then depending on the position of the switch it goes through a different size resistor and returns the voltage on the White/light blue wire.
So we need to go to the GEM and move the switch through the different positions and make sure the voltage changes. If it does not, then the switch is the issue. If it does, then we need to go to the Brown Pink wire of the GEM in pin 17 and find out if there is voltage coming out there. That is telling the shift module to engage the motor. If there is no voltage then the GEM is the issue. If it does then the shift module is the issue.
However, I suspect the switch or the GEM is the issue.
Let's run through this and go from there. Thanks
Dec 14, 2020 at 1:24 PM
STEVEMACDONALD
2 wheel switch to 4 wheel high and low is on the dash lights wont come on when switched on they also dont come on when engine ignition is turned on I was wondering if it is the transfer case motor I have checked all fuse's inside truck and on fire wall they are fine is there is no codes at this time to read
Dec 21, 2020 at 9:56 AM (Merged)
RACEFAN966
  • 5,029 POSTS
Yes it could be the t-case motor it could also be the gem module but not near as common. If you want to test it let me know and you will need a digital multi meter.
STEVEMACDONALD
Yes I would like to test the motor before buying one if possible I do have a meter
Thanks again
RACEFAN966
  • 5,029 POSTS
Ok first thing that needs to be done is make a fused jumper wire. Now you need to get to the GEM module (it is behind the radio). Now unplug it and put the jumper wire from pin 10 and ground turn on the key engine off and if the 4x4 light comes on the module is bad. Also measure for voltage between pin 14 and ground if voltage is present then you need to repair the gray wire from pin 14. Here is some pics the first is a pic of were the gem module is and the 4x4 relay which we will test next. The second pic is of the connector and the pin numbers. Let me know how it goes and we will go from there.
https://www.2carpros.com/forum/automotive_pictures/249564_components_1.jpg
https://www.2carpros.com/forum/automotive_pictures/249564_pin_numbers_1.jpg
SCOTTPAYNE1
4x4 wont engage just makes a clicking sound from glovebox area already checked fuses inside car and under hood
I need you to check if the actuator on the transfer case is getting power. Have a helper try switching to 4wd while you check for power. Please make sure the park brake is on.
Let me know what you find.
SUZYQ41S
2001 Ford Explorer
my four wheel drive won't work and the light won't come on that tells me it is in four wheel drive
Dec 21, 2020 at 9:57 AM (Merged)
It can be cause by a couple things, vacuum to the front axle, or the electric actuator. IF the light isn't coming on, I would start by checking if there is power to the actuator on the transfer case. If there is, remove the actuator and check it for function.
ROBUCK1
Front axle will not engage even though lights do come on showing it is engaged. my email [email protected]
Good morning,
when you command 4 wheel low, does it feel like it is in 4 wheel low?
It is possible the actuator is bad on the transfer case but needs to be confirmed.
I attached possible issues but I need the code stored in the module to narrow the area of failure.
ROBUCK1
The lights do come on, and the motor runs (you can hear it and feel it). Is my problem in the transfer case and what could it be?
Okay, got it. What tests have you done so far?
Again, do you have the code for the system?
I want to help but I need a starting place and the code will narrow the field of testing.
ROBUCK1
The motor was removed and checked for movement (running) when activated with the buttons on the dash. It seemed to work fine that way, along with the lights coming on as they should. Also when motor is installed, and you work the buttons you can feel and hear the motor running. This would seem to indicate that the trouble is in the transfer case. If that is so, what would it be? I hope this ID plate gives you the code.
It does sound like your transfer case is the issue as it is most likely and internal failure.
Is the check engine light on and if it is, do you know the codes?
PREACHERTOO
The buttons on the dash board that allow you to select between 4wd auto, 4wd high and 4wd low, nolonger do anything nor do they light up the indicator on the dash. the ar will not go into 4wd, it has been serviced regularly and runs well otherwise. several shops have been stumped and can not figure what is wrong. no codes appear in a scanner according to the last repair shop. any idea what I can do.
2CARPRO JACK
  • 11,533 POSTS
Start by checking Maxi-fuse #1,4,6 in the underhood power center,then check fuse #25,26,28,9. If all good, remove the switch and using a test light verify power to the switch, and that the switch is passing the power through it when a differnet range is selected.This could be the electronic shift control module, the G.E.M. module or the motor on the transfer case.You could also test for power at the motor on the t-case when differnet ranges are selected.
EZE46
The 4x4 and 4x4 low lights are flashing and will not engage into 4wd, and the truck resently went into the sand about 3 weeks ago and had no problems untill now. the 4wd is hardly used. What could be the problem?
Check the wiring to the actuator on the transfer case. If it is clean and tight, check to see if there is power getting to it.
