my 1991 f150 lariat xlt with a 300strait 6cyl
1991 FORD F-150
163,000 MILES
RANDLE357
  • 6 POSTS
it will start and idle but after about 5or10seconds the CEL comes on and the charge hand drops and when i try to pull out fast it dies.but if i slowly press the gas it does fine. i have changed alot of things i replaced the TPS, MAP, o2sensor,idle air control and i put new plugs&wires
Sep 2, 2013 at 8:52 PM
SATURNTECH9
  • 30,869 POSTS
At idle what does the voltage read at the battery?
Sep 2, 2013 at 10:06 PM
RANDLE357
  • 6 POSTS
how do i check my battery.thanks.
Sep 3, 2013 at 6:22 AM
SATURNTECH9
  • 30,869 POSTS
With a multi meter with the engine idling you measure the voltage at the battery where the battery cables hook up.Were not tested the battery like that were see what the voltage at the battery is at idle.
Sep 3, 2013 at 7:29 AM
SATURNTECH9
  • 30,869 POSTS
You need to make sure the battery cables are clean and tight and have the battery tested at the auto parts store.
Sep 3, 2013 at 7:30 AM
RANDLE357
  • 6 POSTS
i tested the voltage at battery at idle it was 14.5 not running it is 12.6 i cleaned all cable ends before i did the test.
Sep 3, 2013 at 12:06 PM
SATURNTECH9
  • 30,869 POSTS
Alright now at idle with the head lights on low beam and the ac on at idle what does the voltage read at the battery?Have you had the battery tested yet?
Sep 3, 2013 at 12:26 PM
RANDLE357
  • 6 POSTS
yes i went to auto zone today they said it was fine.did i forget to add that my truck spits and sputters when i try to pass another car
Sep 3, 2013 at 3:05 PM
SATURNTECH9
  • 30,869 POSTS
So does the battery light only come on when the rpm drop real low?What codes are you setting you said the check engine light comes on.
Sep 3, 2013 at 10:31 PM
RANDLE357
  • 6 POSTS
i do not have a battery light only a gage with a hand. as far as codes i have not done a test yet.i will today. the rpm only drops a little bit. this problem started when i let a friend try to fix my starter switch i dont know if he shorted somthing out or not but be for he worked on it. it ran fine.
Sep 4, 2013 at 7:38 AM
SATURNTECH9
  • 30,869 POSTS
Have you checked all the connections to the starter to make sure there tight with the battery unhooked of course?Also see what codes you have and check for any blown fuses.
Sep 4, 2013 at 9:45 AM
RANDLE357
  • 6 POSTS
hi.i drove my truck today it ran good untill i tried to press the gas past a half pedle then it started choking out and spurttering.
Sep 4, 2013 at 12:04 PM
SATURNTECH9
  • 30,869 POSTS
Have you checked for codes yet?Also have you checked all the fuses?
Sep 4, 2013 at 4:47 PM
