Those are both codes for Bank 1 A/F sensor heater. See diagnostic chart below
DTC P1166: A/F Sensor (Sensor 1) Heater Circuit Malfunction
1. Reset the ECM/PCM.
2. Start the engine.
Is DTC P1166 indicated?
YES - Go to step 3.
NO - Intermittent failure, system is OK at this time. Check for poor connections or loose wires at C102 (located under the under-hood fuse/relay box), A/F Sensor relay, the A/F Sensor (Sensor 1) and the ECM/PCM.
3. Check the following fuses:
- POWER SEAT (20 A) fuse in the under-hood fuse/relay box.
- No.4 ECU (ECM/PCM) CRUISE CONTROL (15 A) fuse in the driver's under-dash fuse/relay box.
- No.6 LAF HEATER (20 A) in the passenger's under-dash fuse/relay box.
Are any of the fuses blown?
YES - Repair short in the wire between the A/F Sensor relay and the fuses.
NO - Go to step 4.
4. Measure voltage between ECM/PCM connector terminals B19 and B20, 30 seconds after the ignition switch is turned ON (II).
Is there battery voltage?
YES - Substitute a known-good ECM/PCM and recheck. If the symptom/indication goes away, replace the original ECM/PCM.
NO - Go to step 5.
5. Measure voltage between ECM/PCM connector terminals C13 and B20.
YES - Go to step 6.
NO - Go to step 10.
6. Turn the ignition switch OFF.
7. Disconnect ECM/PCM connector B (25P).
8. Turn the ignition switch ON (II).
9. Connect ECM/PCM connector terminal B16 to body ground with a jumper wire, then measure voltage between ECM/PCM connector terminals B19 and B20.
NO - Repair open or short in the wire between A/F Sensor (Sensor 1) and ECM/PCM (B19).
10. Turn the ignition switch OFF.
11. Disconnect ECM/PCM connector B (25P) and the A/F Sensor (Sensor 1) 4P connector.
12. Check for continuity between A/F Sensor (Sensor 1) 4P connector terminal No.3 and body ground.
Is there continuity?
YES - Repair short in the wire between the A/F Sensor (Sensor 1) and ECM/PCM (B19).
NO - Go to step 13.
13. Turn the ignition switch ON (II).
14. Measure voltage between ECM/PCM connector terminals B16 and B20
YES - Repair open in the wire between the ECM/PCM (C13) and the A/F Sensor (Sensor 1) or Secondary HO(2)S (Sensor 2).
NO - Go to step 15.
15. Check for continuity in the wires between A/F Sensor and the fuses.
YES - The wires are OK. Replace the A/F Sensor relay.
NO - Repair open in the wire between the A/F Sensor relay and the fuses.
The corresponding diagrams are attached below
Jun 25, 2021 at 11:09 AM
(Merged)
