Multiple problems surrounding brake issues?
2011 CHEVROLET AVEO
144,392 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
MLNAILL42069
First I got in my car the other day and I couldn't get it out of park, I Google it and found out about the shift release button above shifter been using it since, then when I googled the possible solution it mentioned fuse (cabin fuse not blown) and brake lights being out (as well as cruise control which I never use) I then realized that my brake lights are out as well. I can't find any fuses or relays under the hood that might go along with the issues. I'm thinking maybe the brake switch behind the brake pedal?? Any help would be greatly appreciated!!!
Aug 5, 2023 at 3:43 PM
CARADIODOC
  • 34,306 POSTS
Fuse # 7 in the inside fuse box is for the stop lights. Start with checking that. You can use this article:
or, since we're only interested in one fuse, just pull it out and inspect it visually. If a new one blows again, we'll need to diagnose the cause. Let me know when it blows and how long the brake light circuit works before that fuse blows.
Aug 5, 2023 at 5:37 PM
