Started noticing a rough idle with higher RPMs and sometimes the engine would act like it wanted to stall while parked in neutral. Went on a drive and when I would come to a stop and engage the clutch/shift into neutral while stopped, the RPMs would shoot up sometimes as high as 5,000 as if I was revving the engine but it was doing that on its own. Next, the Slow Down 5/8 light came on and went off twice indicating the cats were beginning to overheat on the driver's side of the engine bank but the light went off.
When I got the vehicle back home, I went to clean the MAF sensors and the throttle body’s. While doing so, I found an oily sludge in the air intake on the driver's side between the MAF sensor and the throttle body.
What could be causing this?
Sep 26, 2024 at 10:07 AM
